Error Pentaho Error connecting to database: (using class org
  • Iniciador del tema Iniciador del tema jigal
jigal
Amig@s:
Soy nuevo en el uso de la herramienta Pentaho, ya lo instale el PDI o kettle y quiero conectarme a una BD Mysql que tengo y lo hago a través de Input Table pero al querer conectarlo y hago test pero me sale este error, ya revise documentación pero no logro correjirle, si alguién sabe mas detalles de como arreglarlo.
Saludos a todos Jigal
Este es el error que me da.
Error connecting to database [mysql] : org.pentaho.di.core.exception.KettleDatabaseException:
Error occured while trying to connect to the database
Error connecting to database: (using class org.gjt.mm.mysql.Driver)
Unknown character set: 'utf8mb4'
at org.pentaho.di.core.database.Database.normalConnect(Database.java:427)
at org.pentaho.di.core.database.Database.connect(Database.java:361)
at org.pentaho.di.core.database.Database.connect(Database.java:314)
at org.pentaho.di.core.database.Database.connect(Database.java:302)
at org.pentaho.di.core.database.DatabaseFactory.getConnectionTestReport(DatabaseFactory.java:80)
at org.pentaho.di.core.database.DatabaseMeta.testConnection(DatabaseMeta.java:2685)
at org.pentaho.ui.database.event.DataHandler.testDatabaseConnection(DataHandler.java:546)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.pentaho.ui.xul.impl.AbstractXulDomContainer.invoke(AbstractXulDomContainer.java:313)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:157)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:141)
at org.pentaho.ui.xul.swt.tags.SwtButton.access$500(SwtButton.java:43)
at org.pentaho.ui.xul.swt.tags.SwtButton$4.widgetSelected(SwtButton.java:138)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.pentaho.ui.xul.swt.tags.SwtDialog.show(SwtDialog.java:389)
at org.pentaho.ui.xul.swt.tags.SwtDialog.show(SwtDialog.java:318)
at org.pentaho.di.ui.core.database.dialog.XulDatabaseDialog.open(XulDatabaseDialog.java:116)
at org.pentaho.di.ui.core.database.dialog.DatabaseDialog.open(DatabaseDialog.java:59)
at org.pentaho.di.ui.trans.step.BaseStepDialog$5.widgetSelected(BaseStepDialog.java:770)
at org.pentaho.di.ui.trans.steps.tableinput.TableInputDialog.open(TableInputDialog.java:435)
at org.pentaho.di.ui.spoon.delegates.SpoonStepsDelegate.editStep(SpoonStepsDelegate.java:124)
at org.pentaho.di.ui.spoon.Spoon.editStep(Spoon.java:8720)
at org.pentaho.di.ui.spoon.trans.TransGraph.editStep(TransGraph.java:3027)
at org.pentaho.di.ui.spoon.trans.TransGraph.mouseDoubleClick(TransGraph.java:744)
at org.pentaho.di.ui.spoon.Spoon.readAndDispatch(Spoon.java:1310)
at org.pentaho.di.ui.spoon.Spoon.waitForDispose(Spoon.java:7931)
at org.pentaho.di.ui.spoon.Spoon.start(Spoon.java:9202)
at org.pentaho.di.ui.spoon.Spoon.main(Spoon.java:648)
at org.pentaho.commons.launcher.Launcher.main(Launcher.java:92)
Caused by: org.pentaho.di.core.exception.KettleDatabaseException:
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:572)
at org.pentaho.di.core.database.Database.normalConnect(Database.java:410)
... 51 more
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown character set: 'utf8mb4'
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:377)
at com.mysql.jdbc.Util.getInstance(Util.java:360)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:978)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3887)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3823)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2435)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2582)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2526)
at com.mysql.jdbc.ConnectionImpl.configureClientCharacterSet(ConnectionImpl.java:1813)
at com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3358)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2278)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2064)
at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:790)
at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:44)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:395)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:325)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:247)
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:554)
... 52 more
