Business Intelligence
Ayuda con ETL
<blockquote data-quote="Imtasariel" data-source="post: 13107" data-attributes="member: 20188"><p>Hola</p><p></p><p>Ojala puedan ayudarme...</p><p></p><p>Tengo unas ETL con conexion hacia ORACLE, al ejecutarlas directamente en el SSIS estan funcionan bien, pero al ejecutarlas a través de un job, estas no se ejecutan y arrojan el siguiente error:</p><p></p><p>Mensaje</p><p>Executed as user: STOMAS\admsqldwh. Microsoft (R) SQL Server Execute Package Utility Version 10.0.2531.0 for 64-bit Copyright (C) Microsoft Corp 1984-2005. All rights reserved. Started: 15:40:32 Error: 2011-12-05 15:40:33.39 Code: 0xC0202009 Source: ETL_LK_ALM_ALUMNO Carga Hora Connection manager "cst_adm.world.gestion1" Description: SSIS Error Code DTS_E_OLEDBERROR. An OLE DB error has occurred. Error code: 0x8007007E. An OLE DB record is available. Source: "Microsoft OLE DB Service Components" Hresult: 0x8007007E Description: "The specified module could not be found.". End Error Error: 2011-12-05 15:40:33.39 Code: 0xC020801C Source: Carga Alumnos desde ORCl Base Alumnos base alumno ORCl [1] Description: SSIS Error Code DTS_E_CANNOTACQUIRECONNECTIONFROMCONNECTIONMANAGER. The AcquireConnection method call to the connection manager "cst_adm.world.gestion1" failed with error code 0xC0202009. There may be error messages posted before this with more information on why the AcquireConnection method call failed. End Error Error: 2011-12-05 15:40:33.39 Code: 0xC0047017 Source: Carga Alumnos desde ORCl Base Alumnos SSIS.Pipeline Description: component "base alumno ORCl" (1) failed validation and returned error code 0xC020801C. End Error Error: 2011-12-05 15:40:33.39 Code: 0xC004700C Source: Carga Alumnos desde ORCl Base Alumnos SSIS.Pipeline Description: One or more component failed validation. End Error Error: 2011-12-05 15:40:33.39 Code: 0xC0024107 Source: Carga Alumnos desde ORCl Base Alumnos Description: There were errors during task validation. End Error DTExec: The package execution returned DTSER_FAILURE (1). Started: 15:40:32 Finished: 15:40:33 Elapsed: 0.468 seconds. The package execution failed. The step failed.</p><p></p><p></p><p>Ya he revisado los permisos y todo lo necesario para que este se ejecute... pero no logro encontrar nada.</p><p></p><p>Muchas gracias.</p></blockquote><p></p>
[QUOTE="Imtasariel, post: 13107, member: 20188"] Hola Ojala puedan ayudarme... Tengo unas ETL con conexion hacia ORACLE, al ejecutarlas directamente en el SSIS estan funcionan bien, pero al ejecutarlas a través de un job, estas no se ejecutan y arrojan el siguiente error: Mensaje Executed as user: STOMAS\admsqldwh. Microsoft (R) SQL Server Execute Package Utility Version 10.0.2531.0 for 64-bit Copyright (C) Microsoft Corp 1984-2005. All rights reserved. Started: 15:40:32 Error: 2011-12-05 15:40:33.39 Code: 0xC0202009 Source: ETL_LK_ALM_ALUMNO Carga Hora Connection manager "cst_adm.world.gestion1" Description: SSIS Error Code DTS_E_OLEDBERROR. An OLE DB error has occurred. Error code: 0x8007007E. An OLE DB record is available. Source: "Microsoft OLE DB Service Components" Hresult: 0x8007007E Description: "The specified module could not be found.". End Error Error: 2011-12-05 15:40:33.39 Code: 0xC020801C Source: Carga Alumnos desde ORCl Base Alumnos base alumno ORCl [1] Description: SSIS Error Code DTS_E_CANNOTACQUIRECONNECTIONFROMCONNECTIONMANAGER. The AcquireConnection method call to the connection manager "cst_adm.world.gestion1" failed with error code 0xC0202009. There may be error messages posted before this with more information on why the AcquireConnection method call failed. End Error Error: 2011-12-05 15:40:33.39 Code: 0xC0047017 Source: Carga Alumnos desde ORCl Base Alumnos SSIS.Pipeline Description: component "base alumno ORCl" (1) failed validation and returned error code 0xC020801C. End Error Error: 2011-12-05 15:40:33.39 Code: 0xC004700C Source: Carga Alumnos desde ORCl Base Alumnos SSIS.Pipeline Description: One or more component failed validation. End Error Error: 2011-12-05 15:40:33.39 Code: 0xC0024107 Source: Carga Alumnos desde ORCl Base Alumnos Description: There were errors during task validation. End Error DTExec: The package execution returned DTSER_FAILURE (1). Started: 15:40:32 Finished: 15:40:33 Elapsed: 0.468 seconds. The package execution failed. The step failed. Ya he revisado los permisos y todo lo necesario para que este se ejecute... pero no logro encontrar nada. Muchas gracias. [/QUOTE]
Ayuda con ETL
